Welcome to Club SAITO !
Old 12-31-2009, 02:01 AM
  #16726
gootchrc
gootchrc's Avatar
Default RE: Welcome to Club SAITO !
Old 12-31-2009, 03:42 AM
  #16727
flashback
My Feedback: (39)
ORIGINAL: gasrchobbyengines
First, I have been rebuilding saitos for my customers for about 6 months now, and I really enjoy how well the engines are made.
I have a few questions,
1) How can I become a member of Club Saito?
2) I am working on converting a nitro saito 120s over to gas and I am trying to find the parts to do the conversion. Does anyone know where I can buy them, or does anyone know who I can pay to make them?
Thanks Saitio club members for all your help. I wish every one a Happy new year.
Chick this person
http://www.rcexl.amderc.com/
He successfully converts SAITO 150 – 180 – 80 to gas
You may ask him for adapter (custom billed) or you ship the motor to him and he will converted to gas and test it or you.
For spark ignition parts, see here
http://www.cncengines.com/orderpage.html
Old 01-01-2010, 08:01 AM
  #16728
Rudolph Hart
Rudolph Hart's Avatar
Hello all and a happy new years flying i hope.It's the reason for this post.I have a friend andrew who is new to fourstroke and a gasser at that.Would some of you be kind enough to hop over to the giant scale thread and help him out? if he does'nt come here.Many thanks,peter
Old 01-01-2010, 08:03 AM
  #16729
Rudolph Hart
Meant to add that it's the h9 taylorcraft thread
Old 01-01-2010, 05:24 PM
  #16730
reyn3545
reyn3545's Avatar
I think I finally got my 450 running right today (or very close to it).
It was flooding out above half throttle, no matter whether the on-board glow was on or off. No matter what I did to the high-end needle.
So, I set the on-board glow to shut off at half throttle, and wound up opening up the Low End needle about a turn. This made me lean up the high-end about the same for a good idle. It was now transitioning very well, and maintaining a decent sound when the glow shut off. I was able to tune it for the high-end, so now it has a good idle and good response through the entire throttle range.
I never would have imagined that the low end was lean... but it looks like it was.
Anyway, it's too cold and windy to try any flying today, but hopefully this weekend the weather will improve.
Old 01-04-2010, 01:21 PM
  #16731
blw
blw's Avatar
Welcome. You are member #672
Old 01-04-2010, 01:34 PM
  #16732
davidgeorge212
davidgeorge212's Avatar
I have a question. I have an OS 160 twin and I have a saito 180. The 160 says it can swing up to a 20x6 prop acording to the manual. The 180 says it can only swing an 18x6 prop. Why do they say a saito 180 cant turn a 20x6 prop and it is a little bigger? Just out of curiosity, what would be the worst thing that could happen if you put a 20x6 prop on a saito 180?
David
Old 01-04-2010, 09:00 PM
  #16733
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
My Saito 2.20 turns a 20x6 at 9,150, the 1.80 rpm would be a little low. What is the 1.60 rpm turning the 20x6?
Old 01-05-2010, 04:08 AM
  #16734
davidgeorge212
I havent really run either yet. I bought the 180 slightly used off of a fellow club member and it has sat on the shelf waiting to go in my airplane, and the 160 I bought brand new off of a guy that was switching to electric in another club.
The airplane I am putting the saito 180 on really doesnt need the power of a 180 but it could probably benifit from a slightly larger prop just for cowl clearance. so even if the 180 drops some RPM's I dont believe it would matter too much on this particular plane.
David
Old 01-05-2010, 04:10 AM
  #16735
davidgeorge212
When I fly it for the first time thought I will be using an 18x6 prop because I dont want to take any chances.
Old 01-05-2010, 09:00 AM
  #16736
yearnin to Fly
My Feedback: (52)
ORIGINAL: blw
Thanks, and happy flying everyone!
Old 01-07-2010, 05:56 PM
  #16737
reyn3545
reyn3545's Avatar
I put a set of OS "F" plugs in my Saito 450 today, and I think that finally cured all of it's evil habits! It started immediately, and once I had a decent idle set, it would quickly go through the entire throttle curve, had better high-end, and transitioned without hesitation. I needed to richen up the high end just a little, and lean up the low end about a half-turn... but after that, it went through several starts, stops, throttle cycles, etc... what a GREAT sounding motor!
Now I've got to get it in the air... but it's snowing outside, and I'm going to New York on Sunday for most of next week. Always something!
Oh, by the way, these things CAN start with the glow system turned OFF!...... I cut my motor off, had the glow system switch on the radio off, and was going to give it a few flips to get some fuel in for the next start... cranked right up! I'm glad it was tied down. I choked the throttle down and chaulked that one up as a lesson learned... if the plugs are hot enough... the fuel will igninte!
Old 01-07-2010, 06:25 PM
  #16738
c550
My Feedback: (16)
Reyn,
What prop are you using. I just got one and can't wait to run it.
Regards,
Dave
Old 01-07-2010, 06:27 PM
  #16739
reyn3545
reyn3545's Avatar
I've got a Xoar laminated 22x10... but I'll probably go to a 12 pitch once it's broken in.
I've also got a Bolly carbon fiber 23x10 that I could use for it, but it wouldn't look very scale.
Old 01-07-2010, 06:29 PM
  #16740
reyn3545
reyn3545's Avatar
Old 01-10-2010, 03:36 PM
  #16741
Daddyo57
My Feedback: (15)
Daddyo57's Avatar
Hi there, been a Saito fan for many years and I am wondering if anyone here has seen or has a Saito FA 80 T Twin engine ? have an old one and I cant even remember how I ended up with to be honest. I am putting it in a Goldberg Cub as I am sure it will be a good match. I have ran the engine and I have to say, it is a sweetheart but not a real powerhouse, no biggy to me because the cool factor of a little twin makes it a real jewel to me. I just have never ever seen or heard of another one!!! I find that odd but this seems to be the place to talk about it. I currently am flying a Saito .50 on a Kadet (plenty of power) and have a Saito .80 with low hours looking for an Astro hog kit (whole other story) and I just got a new 1.25 Golden Knight. I litteraly wore out an old Saito 1.20 on an old Dalotel years ago what a sweet runner! I like the idea of being a Saito Club member and I have my AMA (173008) how do I join up?
Thanks, Daddyo57 aka Cliff Keeling[8D]
ID:	1353452   Click image for larger version
Old 01-10-2010, 08:57 PM
  #16742
kq4ra
Beautiful Twin
ORIGINAL: Daddyo57
Old 01-11-2010, 04:08 AM
  #16743
The Raven
The Raven's Avatar
A club member has been trying to sell his FT-70 twin for some time. Everyone is wondering if it's powerful enough to suit anything. So let me know how your 80 goes....it may inspire me to add it to my collection.
Old 01-13-2010, 11:12 AM
  #16744
Slats!
Hi, I have a saito 1.00 and would like to program a 9 pt throttle curve on my TX for this engine. Does anyone have any advice on what percentages they use on the various points or have done this in the past. Thanks
Old 01-13-2010, 11:14 AM
  #16745
w8ye
My Feedback: (16)
w8ye's Avatar
I havn't run a curve but have used a bunch of expo on the throttle. Worked pretty good I thought. I still have it that way. Makes the throttle response more linear.
Old 01-13-2010, 11:36 AM
  #16746
Slats!
Yah thats exactly what I am looking for. It seems the engine had 3 speeds with my old TX last yr, the new one has curves that I can set up so I want to give it a try..
Old 01-13-2010, 11:45 AM
  #16747
blw
blw's Avatar
I've done other curves but not for the throttle. I always thought I would find the 50% throttle point with a tach, and adjust the curve to match center of the throttle stick position. I would then adjust a few points from there........
Old 01-14-2010, 11:40 AM
  #16748
blw
blw's Avatar
Finally!!!
A nice day for breaking in a great engine like the 82a. It will have a Turboheader muffler on it the next time it runs.
Old 01-14-2010, 07:07 PM
  #16749
BP5589
To blw,
I have a 180,182 twin,2.2 and a 5cyl radial, can you join me up?
Bill
Old 01-16-2010, 11:59 AM
  #16750
blw
blw's Avatar
Bill- you are member #674
